secondary air injection pump vacome lines
118,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
FRANK GULLETTE
trying to hook up vacuum lines to electic air controle pump
Apr 19, 2014 at 11:22 PM
hello my name is roy and I will assist
there is am electrical connector for power, an inlet line for air and an outlet line for air to a check valve and then that goes to the exhayst manifold. the check valve should have 1 vacuum line attached that is manifold vacuum from the intake manifold.
Apr 25, 2014 at 6:01 AM
