Seatbelt at the time of the collision?
25,000 MILES • 2.0L • 4WD • AUTOMATIC
TAMMY3510
The brakes were out for my SUV. While on the hill, the car shut off and the foot brakes got hard. The car picked up full speed and ran down off the hill and left the front wheel damaged especially the right side. The airbags in the front both driver and passenger were deployed.
I was not wearing my seatbelt at the time of the collision, and it was me alone inside of the car.
I am currently fixing the car. Do i still need to change the seatbelt even if it was not in use?
Jan 25, 2025 at 8:55 PM
STEVE W.
  • 15,405 POSTS
As both airbags were deployed you will need to replace both of them, plus you will need a scan tool to go into the airbag control module and see which sensors triggered it to deploy the bags and replace those as well. Because it did deploy both driver and passenger bags, I'm going to say that both seat belts deployed as a result. Use a scan tool to check all of the sensors as well as the occupant classification system and the remaining air bag modules.
The newer SAS systems like yours have a few options for sensors and deployment based on things like seat sensors, door sensors, speed inputs and more, with the scan tool you can "see" the faulty parts and tell when they are repaired. However, because some items are optional depending on where it was built and which option package it has, there is no real way to tell which sensors triggered without the OE level scan tool.
Jan 25, 2025 at 10:05 PM
TAMMY3510
Does the Mazda cx3 2018 and the Mazda 3 2018 have the same size engine subframe cradle?
When replacing the passenger front airbag, do i need an entire dashboard replacement or i can just put in the new airbag in the current dashboard ?
Feb 1, 2025 at 9:54 PM
STEVE W.
  • 15,405 POSTS
The subframe is different because of the 4WD system. For the airbag it depends on the damage. If it tore the pad, then yes you replace it. Usually, you end up replacing it because of the way it deploys.
Feb 2, 2025 at 3:35 AM
