2003 SEAT Ibiza BBY Engine
63,000 MILES • 4 CYL • 2WD • AUTOMATIC
SIMONUTT
Hi there
I am about to buy a salvaged BBY engine to replace the existing one (cam belt broke at speed). The model numbers are the same.
Are these engines different for an automatic to a manual or can they be adapted by changing the flywheel.
Many thanks for your help.
Jun 20, 2010 at 10:23 PM
  • 31,937 POSTS
The engine should be the same, the fly wheel will should bolt up the same, just make sure that you install a new spigot bearing in the end of the crank as the auto dose not use one.
mark (mhpautos)
Jun 21, 2010 at 12:22 AM
