1999 SEAT Ibiza
1999 SEAT IBIZA
HESHAME120
Engine Cooling problem
1999 SEAT Ibiza 4 cyl Two Wheel Drive Manual
hii i`ve seat ibiza 1999,i`ve problem in my engine that it doesn`t heating up to the normal temp. to be stable and working probably,the acceleration in the car and its performance is not good now and all that after i change the water pump of the coolent engine and i see now that there is a leakage in the output of the engine exhaust and the piping because when i change the water i put green water especially for the coolent so i can see the leak of water from this place,so i hope that i could know the reason and how i can fix it...,thankx
May 6, 2010 at 7:08 PM
  • 31,937 POSTS
Hi there,
If you have engine coolant coming out the exhaust, you will have to get the engine checked for a head gasket problem start here.
mark (mhpautos)
May 6, 2010 at 7:13 PM
