Seat belt light intermittently turning on when the seat belt receptor is connected?
180,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RPJ
  • 109 POSTS
The seat belt light intermittently comes on when the seat belt receptor is connected. It may flash and I hear the "tone" for a few seconds, then goes away.
Should the receptor be replaced or is there something else I should look into?
The receptor was replaced about 5 years ago.
Any help is appreciated.
Thanks,
Roosevelt.
Apr 27, 2025 at 8:47 AM
  • 55,797 POSTS
Sure, this can happen when the passenger side seat has something on it or the seat sensor is getting weak and thinks there is someone sitting in the seat. I would connect the passengers seat belt to see if the problem goes away. Please let me know.
Apr 28, 2025 at 4:31 AM
RPJ
  • 109 POSTS
Thanks for your reply. I forgot to mention that the tone is on the driver's side when I'm driving.
Does this change the diagnosis?
Thanks, Roosevelt
Apr 28, 2025 at 4:49 AM
  • 55,797 POSTS
Yes, it does, so there is a switch inside the buckle that is bad which makes the waring light/chime come on. You will need to replace the buckle to fix the problem. I would check ebay.
Apr 29, 2025 at 2:28 AM
RPJ
  • 109 POSTS
Thank you very much Ken for your help. I will look into finding the part and let you know what happens.
Roosevelt.
May 5, 2025 at 11:04 AM
  • 55,797 POSTS
I am fixing this problem right now on a Kia, I got the part from ebay for $60.00. Wish me luck!
May 6, 2025 at 3:18 AM
RPJ
  • 109 POSTS
Thanks, I've found a universal fit on eBay, I guess this will work.
I'm concerned because it's low priced but it's a new part.
Roosevelt
May 6, 2025 at 3:37 AM
  • 55,797 POSTS
Okay, let me know what happens.
May 6, 2025 at 4:22 AM
RPJ
  • 109 POSTS
Thanks.
May 6, 2025 at 4:30 AM
RPJ
  • 109 POSTS
Thanks Ken,
I have the replacement buckle. The connector needs to be changed, other than that it seems to be the same. It should work.
Thanks again for your help.
Roosevelt.
Jun 9, 2025 at 6:48 AM
  • 55,797 POSTS
Good job, fixed it for less, that is what we are all about.
Jun 10, 2025 at 4:29 AM
RPJ
  • 109 POSTS
Thanks bro
Jun 10, 2025 at 4:43 AM
