seat belt dinging
130,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DOLPHINLADY64
Hi, no matter I do that seat belt dings it stops for a little bit and then starts and goes on for like forever. I do wear my seat belt.
Aug 30, 2019 at 8:29 AM
The seat belt buckle has a switch inside it that when you put the belt in it, it turns off the chime. When that switch fails, it does not know that the belt was plugged in. Unfortunately, the only repair is to replace the buckle.
I am trying to locate a procedure for replacing the seat belt buckle but I am not finding one in Alldata. I will look for a video if you are going to attempt to replace it yourself.
Thanks
Aug 30, 2019 at 9:07 AM
DOLPHINLADY64
Thank you so much!
Aug 30, 2019 at 10:07 AM
You are welcome. Please let me know if you need more information. Thanks
Aug 30, 2019 at 10:22 AM
