Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
Town Car
Engine
Cylinder Head
Valve Cover
Gasket
Replace/Remove
Is sealant needed when replacing valve cover gaskets
2001 LINCOLN TOWN CAR
118,000 MILES • V8 • AUTOMATIC
CHEVY__88
MEMBER
do i need to use any sealant when replacing brand new valve cover gaskets?
Feb 24, 2018 at 3:02 AM
Experienced Mechanic
Good afternoon.
No, do not use any sealant on new gaskets.
Feb 24, 2018 at 3:38 AM
CHEVY__88
MEMBER
Not even around the mating joints timing cover/cylinder head?
Feb 24, 2018 at 4:19 AM
when tightened down and torqued, the gasket will fill in the gap.
Feb 24, 2018 at 6:37 AM
CHEVY__88
MEMBER
Okay, so do you usually have to take the brake booster off? Seen quite a few videos where they do and they do not.
Feb 24, 2018 at 6:41 AM
Yes, I do. I make it easy on myself. It takes longer but is easier with it off.
Feb 24, 2018 at 6:42 AM
CHEVY__88
MEMBER
What about the passenger side? Anything extra that needs to come off?
Feb 24, 2018 at 8:13 AM
no, just a matter of moving as much out of the way as possible. it comes up easily.
be careful of the wiring.
Feb 24, 2018 at 8:29 AM
CHEVY__88
MEMBER
How do I know if my car is equipped with ABS? The manual was saying not to remove the master cylinder if it is equipped. To let a professional do it.
Feb 24, 2018 at 10:55 AM
you would have a yellow ABS light on the dash when you turn on the key that would say ABS.
you do not remove the master cylinder, just unbolt it and pull it forward and over with the lines attached.
Feb 24, 2018 at 10:59 AM
CHEVY__88
MEMBER
Okay, yeah I only need just a little bit more room. Tried taking it off without messing with that stuff.
Feb 24, 2018 at 11:03 AM
take your time.
it is always so close. just do not damage anything.
Feb 24, 2018 at 11:09 AM
CHEVY__88
MEMBER
Is there any tricks to it? I just cannot seem to get either one off. I loosened the master cylinder.
Feb 25, 2018 at 2:46 AM
Did you remove it? then you need to remove the booster. Did you do that?
Feb 25, 2018 at 7:06 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
