SDM module
107,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JEFFELECTRIC
  • 12 POSTS
I have the SDM module in my hand but I cannot remove the connector from it, is there a trick to getting this off.
May 25, 2017 at 7:18 AM
HMAC300
  • 48,601 POSTS
it may have a clamping lock on it which you pull up on it it locks down when you pull up it will unlock or should then the connector can come out.
May 25, 2017 at 9:01 AM
JEFFELECTRIC
  • 12 POSTS
It has a black tab that I pulled out but still cannot remove the connector. It also has two plastic tabs on the side of the connector that I lift up with still no luck.
May 25, 2017 at 11:18 AM
HMAC300
  • 48,601 POSTS
take a picture and send it maybe I can help you out
May 25, 2017 at 11:10 PM
