SCREETCHING SOUND FROM REAR OF ENGINE
200 MILES • 4.8L • V8 • 2WD • AUTOMATIC
SEACAPTAINCHRIS HARRIS
Not a belt happens not at idle but gets louder as i accelerate. the harder i gas it the louder it gets.
Mar 30, 2017 at 1:48 AM
HMAC300
  • 48,601 POSTS
check to see if something rubbing against flywheel or torque converter bolts loosened up.
Mar 30, 2017 at 2:44 AM
STEVE W.
  • 15,423 POSTS
For a test, with a cold engine, remove the serpentine belt and see if the noise is still there. a bad idler or tensioner or accessory could be fooling you. Running it for a minute or two without the belt will eliminate that either way.
Mar 31, 2017 at 9:25 AM
