out of my driveway I hear an extremely loud screeching noise
105,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
CATHYRSTEVENS
when i back out of my driveway I hear an extremely loud screeching noise.This has continued and is so loud you can hear it inside the house. I've asked the mechanic to look at it and hes says we need new front brakes can you help?
Jul 9, 2020 at 10:31 PM
Here is a video to help you step by step with instructions in the diagrams below to show you how on your car.
https://youtu.be/Gzgh_LVAIDE
and
https://www.youtube.com/watch?v=mOyHFT0hoKc
Plus here is the process from the manual on how to replace these as well. Please let us know if you have other questions. Thanks
Apr 2, 2021 at 8:57 AM
SHAHWEZKHAN
  • 5 POSTS
my car need brake pads and rotors to help me save money I will do the job myself can you please give me instructions?
Apr 5, 2021 at 3:45 AM (Merged)
Good morning,
I attached a breakdown of the front brakes for you to view. I also attached a guide for the procedure for replacing the pads and rotors.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
I attached a YouTube video of the procedure as well.
https://www.youtube.com/watch?v=fGp6sGHWQmA
EBONIDG
I have a 2005 Toyota 4Runner Sport Edition 2WD V6 4.0L, and I need brake pads. What are some good brands for this vehicle? Also I am not sure if I need front or rear or both.
Apr 5, 2021 at 3:46 AM (Merged)
CARADIODOC
  • 34,414 POSTS
The cheapest pads you can find will be fine. That's not to say your vehicle came with cheap pads, just that it costs just as much to make less-expensive linings as it does to make expensive ones. What the manufacturers have to be very careful of is that their linings have the same "coefficient of friction" as the original ones. That is important to maintain the braking balance between the front and rear brakes. You do not want new front pads that can lock up the wheels easier than the rear ones. The only way to know which linings must be replaced is to perform an inspection. With the age and mileage you listed you are probably doing a lot of highway driving so the rear linings are probably fine yet.
JASMAN56
brake warning lights come on and I can hear the brakes grinding. thank you for your help.
Apr 5, 2021 at 3:47 AM (Merged)
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Below you will find the process from the manual on how to replace these. Let me know if you have other questions. Thanks
SUMDUMFK
How do you pull a rotor off of a 2002 Four Runner? Front rotors Braking system completly nothing but dust caps and rotor!!! Pulled front dust cap no help without a tool!!! Is there a press involved!! Do you need a tool a fly wheel puller or something like it? Or do you go through the large dust plate in the back of the wheel mount and knock the rotor out that way? Signed Stumped!!!
Apr 5, 2021 at 3:48 AM (Merged)
BLACKOP555
  • 10,386 POSTS
the rotors are probably rusted around the center. spray all around the inside of the center of the at the center and around the lugs to try and loosen it up. then heat it up and hit on it with a hammer between the lugs till it comes off.
97NIK
What is up with the front rotors? I had mine replaced less than 2 yrs ago and they warp fast.
Apr 5, 2021 at 3:52 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
It could be the way you drive if your hard on the brake's and make short stop's.You could also have a sticking front caliper.Also if you have rear drum's brake's and there out of adjustment that can warp your front brake's because all the braking is being done in the front and the rear isn't helping with the braking.
