screeching sound in ignition start
106,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PCULQUI
  • 354 POSTS
My vehicle starts fine but at the very end of turn on before reading key, there's a small screeching sound. Like a 2 second time frame. Usually happens in the morning after the car has been sitting there overnight.
Jun 24, 2020 at 5:52 AM
  • 110,251 POSTS
Does this happen when the engine first starts or as soon as you put the key in the ignition? Also, can you tell approximately where the sound comes from? For example; does it seem to be under the dash, under the hood and so on?
If at all possible, could you record it and upload it for me to hear and see what is happening?
Jun 24, 2020 at 12:38 PM
PCULQUI
  • 354 POSTS
no, not at start-up but right before the car turns on and I let the key go since the car is on.
Jun 24, 2020 at 1:12 PM
  • 110,251 POSTS
Does it seem to be coming from under the dash? Is it possible to record and upload the sound so I can hear it? I'm questioning if it is something with the HVAC. One of the actuators or air flow doors may be moving and creating that sound.
Jun 24, 2020 at 2:29 PM
PCULQUI
  • 354 POSTS
Okay. I'll record the sound and send it over. If it is as you said, does the actuator need replacing or just tightening up and where would they be located.
Jun 24, 2020 at 8:27 PM
  • 110,251 POSTS
Often times it will need replaced, but I would like to hear it before I suggest anything like that. I hope you understand.
Jun 25, 2020 at 1:33 PM
PCULQUI
  • 354 POSTS
I was trying to record it but now it's not happening anymore. So I have to wait until it happens again.
Jun 25, 2020 at 7:51 PM
  • 110,251 POSTS
Not a problem. Let me know when you get it to happen again.
Jun 26, 2020 at 1:32 PM
