Scraping noise when driving at higher speeds
225,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
KARAN SINGH
When I’m driving on a freeway, at speeds of 55-60-65 my car’s front right side starts making a scraping noise that grows stronger as I accelerate, soon as I let up the noise slowly fades away. This could be a variety of things but I’m not sure which, if it’s something that I can avoid going to the mechanic’s and repair myself I’d be glad to know, or if it’s too much for a novice I’ll take it to the shop. But I just want a name for the part or what issue this could be that needs replacement or fixing? I’ve heard brake pads/shield might be the culprit, but I guess I’ll just have to ask those who know better.
Jan 19, 2021 at 9:52 AM
This sounds like you are having a bearing issue but it is odd that it doesn't come in until higher speeds.
So let's start with getting a recording of the noise so that we can hear what it sounds like.
Here is a guide that will help with scraping noises in general but hearing the noise will really get us on the same page:
https://www.2carpros.com/articles/vehicle-scraping-noise
Let us know and we can go from there. Thanks
Jan 20, 2021 at 10:07 AM
KARAN SINGH
Hello, it turned out to be that my brakes were very well worn and needed replacing, and were the source of the scraping noise. Thank you for your advice though.
Mar 3, 2021 at 11:29 AM
Got it. That is great info as normally worn brakes make the noise at slow speeds and get worse at higher speeds and may even go away at higher speeds. So it is good to know that this is not always true.
I am sure this info will help others that have a similar issue. Thanks for using 2CarPros. Please come back.
Mar 3, 2021 at 11:07 PM
