Scored cylinder bore?
131,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
JRUSHER
  • 13 POSTS
I recently rebuilt a 351w - it is completely stock except for a mild cam. While going through the flat-tappet cam break-in, I noticed a miss above 1500 rpm. I inspected the plugs and #4 was fouled (wet), all others were fine. I swapped plugs and then wires and there was no change. I did a compression test, and all cylinders were 150+/_5. I ran a borescope into the bore, and noticed both radial and vertical scoring on #4, all other cylinders were okay. It looks like possible oil starvation. What do you think?
Nov 18, 2024 at 3:17 AM
  • 55,690 POSTS
Yep, the walls do not look good on #4, like you had contamination when the engine has assembled, or something is wrong with the piston rings. I would remove that piston to see what's going on. There is a problem with the oil control on that piston as well. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Nov 18, 2024 at 4:28 AM
