I need to check the fuses. Thank you. Len
7,500 MILES • 4 CYL • 2WD • AUTOMATIC
LKAMENS
The blinkers stopped working I need to check the fuses. Thank you....Len
Jun 13, 2010 at 2:32 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here are a few tutorials for you to view on how to check and replace fuses:
I've attached pictures below showing the fuse and relay locations on your vehicle. Hope this helps and thanks for using 2CarPros.
Jun 16, 2021 at 4:40 PM
