2006 Scion xB Running too warm
2006 SCION XB
15,200 MILES • 4 CYL • FWD • MANUAL
CHOPPERFRITZZ
My Scion runs warmer then normal after short trips
Feb 5, 2009 at 7:43 AM
MECHTRIX
  • 529 POSTS
theres a small plastic bottle called a "catch tank" or coolant overflow resivior" you will see a small rubber hose running from the top of your radiator near the cap you can follow it down it will lead you to the coolant tank.... on the side of the tank you will see upper and lower level markings which indicate how much coolant is needed or if any is needed at all ...if it's at the lower to mid level " just ad a little coolant till it reaches the upper level but be carefull as the coolant can be very hot if you let the car cool off for oh' a 1/2 hour or so" before hand ....it should be ok" "good luck ' hope this helps.
Feb 5, 2009 at 7:58 AM
CHOPPERFRITZZ
[quote:f20439c4c6="mechtrix"]theres a small plastic bottle called a "catch tank" or coolant overflow resivior" you will see a small rubber hose running from the top of your radiator near the cap you can follow it down it will lead you to the coolant tank.... on the side of the tank you will see upper and lower level marking which indicate how much coolant is needed or if any is needed at all ...if its at the lower to mid level " just ad a little coolant till it reaches the upper level but be carefull as the coolant can be very hot if you let the car cool off for oh' a 1/2 hour or so" before hand ....it should be ok" "good luck ' hope this helps.[/quote:f20439c4c6]
Thank you Mechtrix you were right,.. Now I feel stupid, levels were low, filled them and everything was right by the time I got back from Kragens. The car is running at normal temp. again, thanks a million you're the best
Feb 5, 2009 at 8:51 AM
MECHTRIX
  • 529 POSTS
good "glad i can help"
Feb 5, 2009 at 8:58 AM
