2006 Scion xB Fuse
SCIONXB
Electrical problem
2006 Scion xB 4 cyl Front Wheel Drive Manual
There was a wire put into the fuse box along with the fuse...causing the fuse contacts in the box to be moved? so when the fuse was replaced by itself it caused it not to have good contacts in the box itself? what to do to solve the issue?
Oct 26, 2008 at 8:52 AM
KHLOW2008
  • 41,812 POSTS
Hi scionxb,
Thank you for the donation.
There are 2 ways of doing it.
1. Use a sharp and pointed object that is stiff to push at the terminals to clamp them closer to get back the contact.
2. If above fails, remove the fusebox and unplug the wire by releasing the lock inside the clip and repair/replace the terminal.
Oct 26, 2008 at 12:52 PM
