2007 Scion tC Starting Problems
38,000 MILES • 4 CYL • FWD • MANUAL
DM_3_13
You turn the key to start it and it makes a "click, click, click" noise. (It doesn't always do it) After the first try sometimes on the second try it will start right up, other times it will do the clicking noise again. Sometimes if you try turning it on and press the gas it will start up, but not always.
Replaced the gas tank filter and cleaned the air flow censor.
Feb 7, 2010 at 3:27 PM
FORDRACING24
  • 65 POSTS
It's most likely your battery. It could also be your starter or alternator.
Jun 18, 2010 at 12:26 AM
