2007 Scion tC clock/outside temp window
RLEMONE
Interior problem
2007 Scion tC 4 cyl Automatic 24000 miles
should this area be lit at night?
mine is not, could it be a fuse?
and where is the fuse box.
thanks,
Nov 19, 2009 at 4:39 AM
COLDPIZZA
I have a 2007 tc that had the same problem. If you start the car without the lights on the clock should be lit up. When you go to turn the lights on it will go off. This should not happen. The whole panel should light up. There is a defective part on the circuit board behind the panel and the whole control panel needs to be replaced. I took mine to the dealer and they replaced it for free.
Nov 29, 2009 at 12:56 PM
