Engine Mechanical problem
2006 Scion tC 4 cyl Automatic
The other day i was driving around, and my check engine light came on, my car idled at about 4rpm, slows down, and cut off. At that time, my battery lamp, and my oil lamp both kick on. I come to a complete stop, wait few seconds, and crank my car back up. at that point, i had no other problems. the check engine light was on for a couple more days, and then it went back out. a couple days later, the same thing happened again, and this time the problem got a lil worse, now some things on the inside of my car are not working. my passenger side window wont go down, when i tried to put the driver side window down, it would only go down as long as i was holding it down, and my sunroof was a lil slow to respond when i tried to close it. I am currently stationed overseas, and there isnt a scion dealership out here. Do you have any suggestions as of to what the problem may be?
Thanks for any info you can provide.
Aug 16, 2010 at 4:37 AM
