2005 Scion tC replacement
2005 SCION TC
SHDY TREE
Drive Train Axles Bearings problem
2005 Scion tC 4 cyl Front Wheel Drive Automatic
need to know how to replace the front wheel bearings
Oct 19, 2010 at 5:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove or disconnect the following:
Front wheel
Hub nut
Wheel speed sensor
Brake caliper
Front disc
Tie rod ends
Lower control arm
Axle from the hub assembly
Steering knuckle from strut
Lower ball joint
Axle hub snap ring
Mount the steering knuckle assembly in a vise.
Using Special Tool 09520-00031 to remove the axle hub from the steering knuckle.
Using Special Tool 09950-40011, remove the wheel bearing from the axle hub.
To install:
Use Special Tool 09950-60020 to press a new wheel bearing into the axle hub.
Using Special Tool 09608-32010, press the axle hub assembly into the steering knuckle.
Install or connect the following:
Axle hub snap ring
Lower ball joint
Steering knuckle mounting bolts
Axle into the hub assembly
Lower control arm
Tie rod ends
Front disc
Brake caliper
Wheel speed sensor
Hub nut
Front wheel
Oct 19, 2010 at 5:28 PM
