After clutch replacement it is hard to shift into first gear
2008 RENAULT SCENIC
980,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JOHN BAKER2
I've had a local garage replace my clutch on my vehicle listed above it has been fine, but when cold I have had trouble getting it in first gear. the mechanic told me to keep the clutch pedal wedged down. I have down for a day it worked fine, but next day the same thing happened again trouble getting it in first gear. i have now left it wedged again will this method work to remove air from the clutch if I leave it long enough?
Jul 7, 2020 at 6:14 AM
Having someone tell you to hold the pedal down to bleed the air is not sufficient. Unfortunately we don't have a manual on this vehicle so I am not able to tell you how to actually bleed this clutch but that is what needs to happen. This is clearly an issue with air in the system so I would take it back to them and ask they bleed it again until this doesn't happen.
Here are some guides that will help explain what is happening:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/throw-out-bearing-replacement
Jul 7, 2020 at 9:26 AM
JOHN BAKER2
Well, I didn't have time this week to take my car back to the garage so I left the clutch pedal pushed down with a wood block from Monday. I took it off Friday and the clutch is working fine. it's Sunday and there's been no problem with it so in this instance maybe only a small amount of air was the problem and and this clutch down method has worked...
Jul 11, 2020 at 11:16 PM
Unbelievable. You are the first one that I have heard of that this actually worked. Good info. I am going to start recommending this more often for those that can take the time to do what you did. Thanks again. Glad you got it all worked out.
Jul 12, 2020 at 11:59 AM
