no communication
118,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
MELVYN27
scanner does not communicate with ECU.
Apr 5, 2019 at 5:48 PM
  • 55,851 POSTS
Can you try the scanner in another car to confirm the scanner operation? then lets check the ALDL fuse #30 in the under hood fuse panel. here is a guide and the wiring diagrams so you can see how the system works and the fuse location:
Apr 8, 2019 at 6:01 AM
