Firing order and how to scan for codes
81,000 MILES • 3.8L • 6 CYL
MIKE.KITZ
Will not start. may have mixed up firing order when changed plugs and wires? How do i get codes without scanner tool?
Oct 22, 2017 at 3:13 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
1-4-2-5-3-6 distributor rotation: Counterclockwise.
Oct 22, 2017 at 3:18 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Here is a diagram:
Oct 22, 2017 at 3:19 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If the DLC has 12 pins it is obdi and if it has 16 it is obdII. If 16 pin you will probably need a scan tool or at least a code reader.
Oct 22, 2017 at 3:22 AM
RENEE L
  • 1,260 POSTS
Hi MIKE.KITZ,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Oct 23, 2017 at 3:52 AM
