Question regarding a repair I had done on my vehicle
110,300 MILES • 3.9L • V6 • FWD • AUTOMATIC
08CHEVYUPLANDERLS
Before taking a 750 mile (round) trip, we took the car to get the oil changed. Part of the oil change is topping the other fluids. When the mechanic's shop was done we had errands to run. Keep in mind it was a wet day; drizzling, not raining. Back to errands: the post office, 6 miles from the shop, we heard an unfamiliar noise as we pulled into the post office parking lot. When we got out of the car we smelled something, open the hood but the smell was gone - we thought the smell must have came from a different car. We went home (six miles again). About thirty minutes. later we drove to the store (one to two miles) and came back home. Later we left again, after about one mile the car's warning started dinging persistently, we pulled over immediately. The gauge was fully to the red (hot). It was night, the street was very dark and we only had the flashlights on our phones. We decided to skip the errand and go back home (one mile). We first let the engine cool and drove back home very slowly. We pulled over and turned the car off half way home to let it cool down again. When we got home the dashboard (finally) read "engine coolant too hot" (or overheating) so we opened the hood and saw that the coolant tank was empty. We filled it with water. In the morning we took the car back to the shop. They said the water line (?) had a leak. I do not believe that. I think they drained the coolant/water tank and forgot to fill it back up (it was 5:30 p.m. closing time when they were done with the oil change). So now we have a quote for $250.00 plus they have to keep the car overnight.
Keep in mind we just wanted an oil change before taking a trip. There were no problems with overheating nor coolant leaks. The only service required, prior to getting the oil changed, are to service the traction, ABS and stability systems as indicated on the dashboard. We were going to do that at a different shop.
Sorry this is so long. I just do not want to leave out any pertinent information. We have had the car three and half months. It had no problem moving us from CA to AZ hauling a large trailer. The previous owners have been car dealerships. By looking under the hood you would never guess it is a 2008 it has been well maintained. Anyway, I was charged $357.52 for what I believe was their fault.
Was I scammed? I would upload a copy of the receipt if I could, but here is the breakdown:
Remove and replace water pump $95.86
GMB 130-9660 water pump $85.00
Disposal fee (antifreeze) $2.00
Anti-freeze Dexcool Red GM OEM $27.99
Labor discount -$25.00
Remove and replace hub assembly $62.00
Shop supplies $3.00
DHA 29513236 Hub Assembly $89.99
Subtotal parts $207.98
Subtotal labor $132.86
Tax 8.100%
Total $357.52
Jan 20, 2017 at 2:58 AM
SATURNTECH9
  • 30,869 POSTS
Why would they drain the coolant on a oil change? Unless they did that by mistake. also, what is with the hub was that the ABS light issue? the charges do not seem out of line. Did you ask to see the old water pump or keep the old water pump?
Jan 20, 2017 at 4:50 AM
STEVE W.
  • 15,370 POSTS
A 2008 with 110,000 miles on it. Probably the original hoses as well. They can look like new and still spring a leak. Happens a lot more than you would think. From the receipt I would say you did pretty good really.
Were you "scammed", I highly doubt it, with the internet and social media any place that was pulling stunt's like draining the coolant would not be in business for long.
Jan 20, 2017 at 6:10 AM
08CHEVYUPLANDERLS
Thank you for your responses. To answer your questions, draining and refilling the coolant was part of the oil change. We did not see nor receive the replaced parts.
Now the check engine light and "service tire monitor system" are both on. We are leary of taking the car back to the shop. This was a wonderful car until the recent oil change. How should I approach the Manager of the shop?
Jan 24, 2017 at 5:59 AM
STEVE W.
  • 15,370 POSTS
Take it to an autozone/o'reily type store and have them scan the codes and post them here. The light can come on for a LOT of reasons, including a bad gas cap!
Service tire monitor system is related to the TPMS module Do you have key less entry as well? Do those work? Something to check, Find the RFA/MDLS fuse 7 in the right hand dash fuse box. It provides power to the keyless entry module which is also the TPMS receiver. Is it blown? If yes you may need a new module. There were a few problems with them early on.
Jan 24, 2017 at 8:44 AM
SATURNTECH9
  • 30,869 POSTS
Start by making sure all the tire pressures are set to what it says on the door.With accurate tire gauge a inaccurate gauge will set the gauge off as well.I would also check and see what codes come up like Steve says.You could also have a bad tire pressure sensor in the tire.
Jan 24, 2017 at 9:38 PM
08CHEVYUPLANDERLS
I will follow your instructions (Steve W. and Saturntech9) and get back to you later today. Thank you!
Jan 26, 2017 at 11:58 PM
