Saying overheating but is it
176,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
VUKSTA22
my vehicle listed above is overheating maybe. I replaced the thermostat the radiator cap and took it to a shop and they said it’s not a head gasket but after driving it for a bit the temperature gauge goes up to hot then to operating temperature then goes back to hot and stays there. the cars head gasket was replaced 15,000 miles ago. Please help.
Jun 8, 2020 at 11:42 AM
  • 110,248 POSTS
What needs done first is to confirm it is overheating. What I use is a thermometer (infrared) type where I simply point at the item to be tested. When this happens, do you ever notice steam from the engine, a boiling sound, or coolant coming from the system? Does this only happen when you are in stop and go traffic? Are the cooling fans turning on?
If there isn't anything that indicates a problem, then suspect the engine coolant temperature sensor is bad.
Let me know as many specifics you can think of.
Jun 8, 2020 at 1:19 PM
VUKSTA22
The fans are kicking on. There are no sounds of boiling water or steam coming out the hood. And it happens anytime, it happens when I’m going down the road and in traffic. Thanks
Jun 8, 2020 at 9:27 PM
  • 110,248 POSTS
What I would do then is to get a thermometer that is made to check the actual temperature of something without touching it. I use an infrared type which I simply point at the item to be checked and it tells me the temperature. In this case, I would point it at the upper radiator hose to see the temperature.
That is what I would suggest. If it is not overheating when it indicates it is, replace the engine coolant temperature sensor.
____________________
If you find it is bad, here are the directions for replacement. The attached pics correlate with the directions.
2000 Subaru Forester L F4-2.5L SOHC
Removal and Installation
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Coolant Temperature Sensor/Switch (For Computer) Service and Repair Procedures Removal and Installation
REMOVAL AND INSTALLATION
pic 1
1. Disconnect battery ground cable.
pic 2
2. Remove air intake duct and air cleaner assembly.
pic 3
3. Disconnect connector from engine coolant temperature sensor.
4. Remove engine coolant temperature sensor.
pic 4
5. Installation is in the reverse order of removal.
Tightening torque:
25 ± 3 N.m (2.5 ± 0.3 kg.m, 18.1 ± 2.2 ft.lb)
___________________________________
Let me know what you find.
Jun 9, 2020 at 2:16 PM
