someone already put the felpro blue not sure how far\bak a few yrs i think. do they go bad like shrink i just did a starter and noticed oil up on manifold runners and all the way down engine also on crank pulley side and car leaks on ground i pulled topcover and i see it's the same gasket set i am about to use and it dont look bad actually. the spark plug hole far\ left has a little oil sitting. is this felpro replacement any good? would silicone help? there's 4 block sensors around starter but none of them looked like leakers. i hate doin work and no improvement!
Jun 16, 2014 at 11:09 AM
