2007 Saturn Vue Hybrid check engine light and battery light
DOODKIDGUY
Computer problem
2007 Saturn Vue Hybrid 4 cyl Front Wheel Drive Automatic
my check engine light and battery lights are illuminated even after having the battery replaced. autozone did a scan on my engine and codes P1a22, P1A26, and P1A29 were the codes listed. we were unable to find what these codes meant. the hybrid system has also stopped working i.e no "ECO" light and charge /assist needle not moving either.
Jul 11, 2010 at 12:46 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Those code's are for hybrid battery 1 2 and 3 low voltage so you have a problem most likely some where in your hybrid battery pack.I highly recommend that you take it too a hybrid specialist or the dealer i don't recommend a do it yourself on the hybrid system the part's are super expensive so if you miss diagnose a lot of money for nothing.Also the danger of the voltage from the battery pack itself and it's system.Also when there is a failure in the hybrid system it will shut down as a safety feature.Have you had all hybrid your campaign's down on your vue?There were a couple one was inspecting the hybrid battery pack for the batteries leaking and if they were found leaking they were replaced free of charge.All the campaigns were done free of charge you could take it to the chevy dealer and see if they were done they might just fix your problem.If you email me your email address i will send you some pics of the battery pack and the acid in the bottom of the battery tray of one of the hybrid battery pack's i replaced the leaking batteries on.My email address is saturntech9@yahoo.com just put in the subject vue hybrid so i know it's you.
Jul 11, 2010 at 7:33 PM
