2006 Saturn Vue Carrier Bearing Installation
60,000 MILES • 6 CYL • AWD • AUTOMATIC
MOBILMORONG
What is the proceedure for removing the drive shaft to the rear axles in order to replace carrier bearing and u joint? How is the drive shaft removed from the transmission? Does the yoke slide out of the forward part of the shaft to replace the carrier?
Apr 1, 2010 at 8:57 AM
BILL HOLCOMB
Are you speaking about the support bearing between differential and U joint? I have problem at that point, don't know if I take in or try myself, have you corrected your problem?
Jul 18, 2010 at 4:20 AM
