2004 Saturn Vue which tranny which gasket (Honda v6)
52,000 MILES • 6 CYL • AWD • AUTOMATIC
JIMSEZZ
This 2004 vue has a Honda engine v6-would it have a Honda tranny too? getting routine filter, gasket, fluid. vin 5GZCZ63444S896xxx,
part number for filter? gasket?
Oct 30, 2008 at 7:49 AM
IMPALASS
  • 3,112 POSTS
Hello –
Here is the info on the fluid and the filter. You will have to check with the dealer for the gasket. I even looked at the Auto Zone site and it did not show they had one.
AUTOMATIC TRANSMISSIONS
Honda 5 Speed, 5AT (RPO MJ7) - 4.5 liters (4.3 quarts)
Honda 5 Speed, 5AT, RTU (RPO MJ8) - 4.1 liters (3.9 quarts)
GM, Continuously Variable Ratio, VT25-E, AWD, (RPO M16) - 6.5 liters (6.9 quarts)
GM, Continuously Variable Ratio, VT25-E, Electronic, (RPO M75) - 6.5 liters (6.9 quarts)
NOTE: ALL capacity specifications are approximate. When replacing or adding fluids, fill to the recommended level and recheck fluid level.
AUTOMATIC TRANSAXLE
ATF Z1 Automatic Transmission Fluid (Saturn Part No. 22717466).
VTi VARIABLE TRANSAXLE
DEX-CVT Fluid (Part No. 22688912).
VTi VARIABLE TRANSAXLE ADDITIVE
DEX-CVT Fluid Additive (Part No. 22697447).
A warning on the type of fluid.
9. Remove the transmission fill plug. Important: Do not use ATF (P/N 21005966 or P/N 21019223). These fluids are not compatible with this transmission.
10. Add approximately 2.7 Liters (2.9 Qt) of Saturn ATF-Z 1 fluid (P/N 22717466) through the transmission fill plug.
Fluid Filter - A/T
Filter
---CVT 24226576
---5 Speed 12589901
Oct 30, 2008 at 9:22 AM
JIMSEZZ
now Im more confused. how can I tell which of these many trannys I have. it IS auto, awd. is the case clearly marked? VIN no help?
Oct 30, 2008 at 12:34 PM
IMPALASS
  • 3,112 POSTS
Sorry about that. I have attached the VIN info so you can see. The problem with what I show is as you see the chart, position 5-6 doesn't match what your VIN has verse the choices. I have also attached two different transmission location/types. You may have to call the dealer and provide this data for the correct info. I don't have access to dealer info like this. I am viewing two different auto manual programs. I hope this helps. Again, sorry for the confusion.
https://images.2carpros.com/forum/automotive_pictures/248015_Saturn_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Saturn_2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Saturn_3_1.jpg
Oct 30, 2008 at 3:10 PM
