2004 Saturn Vue Power Windows Circuit
30,000 MILES • 6 CYL • FWD • AUTOMATIC
TIMEPORT01
Recently it has twice blown 30 A Maxi fuse for power window & sunroof circuit. All motors work fine and it worked well for a couple of weeks. Presently it's all okay but it could happen again. It does not blow while going over rough road but I suspect it happens some time between when I park it and turn it off and go back later to start the car. Could the window relay have an intermitent short to ground during energizing or de-energizing? Somebody told me to install a 30 A circuit breaker instead of fuse but that doesn't seem like a proper fix. Any suggestions would help.
Oct 12, 2008 at 2:26 PM
DOCFIXIT
  • 18,828 POSTS
I show a 40 amp fuse for that circuit which also does sunroof if you have. A 30 amp circuit breaker is built into window relay.
Oct 15, 2008 at 8:21 AM
