2004 Saturn Vue oil light
2004 SATURN VUE
HENDOG2006
Engine Mechanical problem
2004 Saturn Vue 6 cyl Front Wheel Drive Automatic
we just had the oil changed but there is an oil light with a tool beside it - i am not low on oil, what is the problem
Oct 15, 2008 at 1:43 AM
2CARPRO JACK
  • 11,533 POSTS
If it is the oil life monitor, try turning the key to the on position with the engine off. Push gas pedal to the floor 3 times within 5 seconds. the light should flash. Turn key off , then start it, the light should be out
Oct 15, 2008 at 5:24 AM
