2003 Saturn Vue vacuum booster
130,000 MILES • 6 CYL • AWD • AUTOMATIC
WALT LAMB
fluid leaking into booster and being sucked into engine.Whats the cause
Jan 30, 2008 at 5:48 AM
  • 75,988 POSTS
The brake master cylinder is leaking thru the primary/secondary cups and also the brake booster master cylinder push rod on the booster is also leaking you got double trouble here.
Need more help don't hesitate to ask
Jan 30, 2008 at 7:02 AM
