2003 Saturn Vue Sub frame bolt
2003 SATURN VUE
45,000 MILES • 6 CYL • FWD • AUTOMATIC
MYRA FRAZEL
Just a reply to an earlier question dated Sat Jul 31 2010at 2:14 om. by mcdodf. A subframe bolt fell from the underside of my Saturn Vue 2003. Took it to the dealer; the cost to replace is $450. Wonder if this is a particular problem to Saturn Vue? Otherwise have had very few problems with the car.
Sep 15, 2010 at 6:53 AM
SATURNTECH9
  • 30,869 POSTS
No it's not a very common problem i haven't seen anything like that happen unless the bolt was improperly installed.If it was put in too loose or too tight other then that haven't come across any kind of problem's with the bolt's staying in.
Sep 15, 2010 at 6:59 AM
DEERAGE
it must be a common problem i know of 3 vue's and they went that way
Jun 21, 2015 at 7:46 AM
