2003 Saturn Vue Service Engine Light
90,000 MILES • 4 CYL • AWD • AUTOMATIC
RMANGUS
My service engine light came on last night. I took it in and had it hooked up to a diagnostic code reader. The mechanic tried several times but did not get a code. Is this common? He said he couldn't even reset the system b/c the reader did not find a code. Why would the light come on if there isn't a problem?
Jan 27, 2010 at 3:46 AM
SATURNTECH9
  • 30,869 POSTS
that code reader can probably only read engine codes u probably have a transmission code or a body control module code.u will need to go have it scanned by someone that has a tool that can do that.let me know what u find.
Jan 27, 2010 at 6:13 AM
RMANGUS
Looks like you were right. I took it to a friend who has a better code reader. It came up with code P0130 - O2 Oxygen Sensor - Bank 1 Sensor 1. My next question... what do I do now and where is the oxygen sensor on an 03 Vue?
Jan 28, 2010 at 8:29 AM
SATURNTECH9
  • 30,869 POSTS
[quote:bfdec3ce51="rmangus"]Looks like you were right. I took it to a friend who has a better code reader. It came up with code P0130 - O2 Oxygen Sensor - Bank 1 Sensor 1. My next question... what do I do now and where is the oxygen sensor on an 03 Vue?[/quote:bfdec3ce51]
ok i need to know if u have 2.2 4cyl or a 3.0 v6 u said u had a 4cyl.but the code doesnt sound right for a 4cyl.let me know.
Jan 29, 2010 at 9:30 AM
RMANGUS
It's a 2.2 4cyl AWD.
Jan 29, 2010 at 9:57 AM
SATURNTECH9
  • 30,869 POSTS
ok then it is o2 senor 1 meaning the o2 sensor thats screwed into the exhaust manifold.u can run thru trouble tree for the code but u would need a code reader that could read engine data.or u could just go ahead and replace the sensor and reset the code and see what happens.u might have to go sears to get a o2 sensor socket to replace it there only like 10.let me know how it goes.
Jan 29, 2010 at 10:47 AM
