2003 Saturn Vue SECURITY & SERVICE LIGHTS ARE ON
100,996 MILES • 6 CYL • AWD • AUTOMATIC
LOUGIRL73
A few months ago, I went out to start my VUE & it wouldn't start. The security light would flash while it was trying to turn over, it usually didn't do that. I left it alone for 15 mins & it started just fine. A day later the security light came on while I was driving. Car handled as normal. Shut the car off once I got home, started it again. No light - no problems. Only had that issue twice & it didn't happen again until this morning. Now the service light is on as well as the security light. Any ideas???
Oct 26, 2010 at 3:42 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation .What i need from you is for you to get your engine computer and body computer scanned for code's.Most auto part's store's can only scan engine and transmission computer's but you can try them.Otherwise you will have to find a shop that can scan the body code's.That is are starting point if we have the code's it's setting then we have a starting point.
Oct 26, 2010 at 3:51 AM
