2003 Saturn Vue Need advice on how to trouble shoot electri
114,000 MILES • 4 CYL • 4WD • AUTOMATIC
KIM_LOMBARD
I just did an engine swap on a 2003 VUE 2.2L AWD automatic.
I have everything "all hooked up" - but it blows the ecm/tcm 10 amp fuse when I apply power by hooking up the battery.
After some head scratching, I eliminated all the connections to one. If the engine oil pressure switch (EOP) is left unplugged, the fuse won't pop - but of course, the engine won't start.
I checked continuity along the wire (light brown / black) and when the wiring harness is unplugged, it doesn't show a short to ground.
SO, I'm stumped. Electrical is not my strong point (can you tell)?
I'd buy a replacement engine wiring harness if I knew that would fix it, but I hate spending money without some assurance of the outcome.
Suggestions?
Thanks, in advance.
Kim
Apr 27, 2008 at 8:02 AM
MERLIN2021
  • 17,250 POSTS
Did you try changing the switch?
Apr 27, 2008 at 9:21 AM
