2003 Saturn Vue my oil was leaking into the coolant
76,000 MILES • 6 CYL • AWD • AUTOMATIC
ROCHELLEFOWLKES
  • 6 POSTS
got gasket work done and poured sealent in to two quarts of oil the checked the radior hose wich had a hole in it. and the engine is running fine will i have to replace my engine
May 21, 2010 at 7:19 AM
LEGITIMATE007
  • 5,121 POSTS
I dont understand, you said you put some type of sealant into the oil? please re explain.
May 21, 2010 at 7:42 AM
