2003 Saturn Vue how to replace rear wheel bearings
70,000 MILES • 6 CYL • AWD • AUTOMATIC
UMPBOB
rear bearing loose and making noise do i replace just the bearing or the whole unit
Aug 19, 2008 at 6:10 PM
SERVICE WRITER
  • 9,123 POSTS
Replace it with a timkin.
This is the only brand that I like to use, too many problems witht he other ones and it has a lifetime warranty.
The hub is held on by 4 bolts from the rear.
The axle nut spec MUST be torqued down to spec, or you'll ruin the bearing.
https://www.2carpros.com/forum/automotive_pictures/30961_vue_1.jpg
Aug 19, 2008 at 10:36 PM
