HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
Vue
Drivetrain
Wheel Bearing
Replace/Remove
2003 Saturn Vue how to replace rear wheel bearings
UMPBOB
MEMBER
2003 SATURN VUE
6 CYL
AWD
AUTOMATIC
70,000 MILES
Rear bearing loose and making noise do I replace just the bearing or the whole unit
Wednesday, August 20th, 2008 AT 1:10 AM
SERVICE WRITER
MECHANIC
Replace it with a timkin.
This is the only brand that I like to use, too many problems witht he other ones and it has a lifetime warranty.
The hub is held on by 4 bolts from the rear.
The axle nut spec MUST be torqued down to spec, or you'll ruin the bearing.
SPONSORED LINKS
Wednesday, August 20th, 2008 AT 5:36 AM
Please
login
or
register
to post a reply.
Related Wheel Bearing Replace/Remove Content
2003 Saturn Vue Rear Wheel Bearing Replacement
Drive Train Axles Bearings Problem 2003 Saturn Vue 4 Cyl Two Wheel Drive Manual How To Replace Rear Wheel Bearing
Asked by
gerrit
1 ANSWER
2003
SATURN VUE
VIDEO
Instructional repair video
GUIDE
CV Axle Bearing Press
This guide will show you how to use a hydraulic press to install an axle bearing into a spindle which holds a CV axle on either the front or rear of your vehicle. We are a...
2002 Saturn Vue 02 Odd Question
Hello, I Have A 2002 Saturn Vue Awd V6 3.0l, It Makes A Grinding Noise On The Right Side When Making Sharp Slow Turns, I Recently...
Asked by
x2006nzl
1 IMAGE
2002
SATURN VUE
Wheel Bearing Problems
I Don't Have Money And Expensive Equipment. I Have Tried So Many Things To Remove My Wheel Bearing Assembly. I Have Taken A Hammer To The...
Asked by
david22
2007
SATURN VUE
04 Saturn Vue Wheel Bearings
Hello! My Saturn Dealership Replaced Frt Wheel Bearing In 2008/also Recommended I Have An Alignment Done As Well. In 2010, Both Front Wheel...
Asked by
pdnemeth
1 ANSWER
2004
SATURN VUE
2007 Saturn Vue Passenger Wheel Bearing
Is There Any Video For Passenger/front Wheel Bearing Replacement, I Know The Steps From The Beginning Till The Break Pads And Routers, It'...
Asked by
Ramiadel
1 ANSWER
2007
SATURN VUE
VIEW MORE
SPONSORED LINKS
Axle Bearing CV Bearing Replacement
Wheel Bearings and Seal Replacement
Online car repair manuals
