2003 Saturn Vue Cylinder 2 and 6 misfire codes also low ope
80,000 MILES • 6 CYL • AWD • AUTOMATIC
JHBLACK7233
I have had a low operating temp code 4 a bit now but has not affected the driving of the vehicle. I believe need to replace thermostat. but just yesterday I seem to have begin loosing alot of power vehicle struggling to make any kind of hill and overall performance is poor. Got a cylinder 2 and 6 misfire code. could the low temp code be causing the problem or is there a seperate issue? Anyone experience this? Thanks
Mar 22, 2010 at 5:31 AM
LEGITIMATE007
  • 5,121 POSTS
yeah I think the low tem is causing the misfire, a thermostat may be a good idea, but I think your problem lies within the engine coolant temp sensor, and as the sensor gets bad it will retard the injector pulse
Mar 26, 2010 at 12:15 PM
