2003 Saturn Vue Car running loud
120,893 MILES • 4 CYL • AWD • AUTOMATIC
KSMCPHERSON
My Saturn Vue has started running loudly when driving around town. Oil is full and clear does not look dirty and I am scheduled to have my brakes done this week as they are overdue. Change oil light comes on, but it is coming up on the next oil change within 500 miles. I live in the high desert and it has been very hot and dry lately so I want to know is there something wrong with the engine, the muffler, the transmission??? I do not think it is the transmission as it drives fine and RPM's are where they should be but it just is driving loudly.
Aug 22, 2010 at 4:46 AM
MERLIN2021
  • 17,250 POSTS
Exhaust would be a roaring sound from under the car, an engine noise would be a ticking, or rapping noise, what type do you have?
Aug 22, 2010 at 5:21 AM
KSMCPHERSON
More like a ticking but mostly just running rough sounding. Definitely not a roaring sound
Aug 22, 2010 at 5:26 AM
MERLIN2021
  • 17,250 POSTS
If it's hot where you are, you may need to use a better grade or higher viscosity motor oil, What are you using now?
Aug 22, 2010 at 5:28 AM
KSMCPHERSON
10/30 when I get oil changes through Oil can Henrys
Aug 22, 2010 at 5:35 AM
MERLIN2021
  • 17,250 POSTS
try going to 15-40 for extreme heat, also if oil level is low, engine will tick. When weather cools, go back to suggested oil by manufacturer. You are supposed to be using 5w-30!
Aug 22, 2010 at 5:48 AM
KSMCPHERSON
Great Thank you I will run down there and get that done today!! Thank you very, very much I was really getting worried about this. I appreciate your help!!
Aug 22, 2010 at 5:57 AM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Aug 22, 2010 at 7:37 AM
