2002 Saturn Vue Fuel Pump
105,000 MILES • 6 CYL • AWD • AUTOMATIC
AMARTICH
My Saturn vue started tunrning the red battery sign on the dashboard, fater 10 minutes idle it turned off. Everything looks fine and it try to start but looks similar as when there is no gas on the tank which is not the case. Took it to the autopart and the computer said :bad voltage regulator (alternator) but the mechanic said bad fuel pump. Replaced the fuel filter and still same. When we pour started fluid on the engine it turns on but then off. Any idea ?
Oct 11, 2010 at 2:52 AM
WRENCHTECH
  • 20,760 POSTS
That's a pretty good indication of a pump problem but power and ground arriving at the pump has to be verified first.
Oct 11, 2010 at 3:21 AM
