Welcome to 2carpros. Com
There are lots of things that can cause engine noises.
Lets start with basics.
First, check the engine dipstick to see if the oil level is low. If low, add oil to bring it back up to the full mark. Is the engine still noisy? Check your oil pressure. A low gauge reading (or oil warning light) would indicate a serious internal engine problem that is preventing normal oil pressure from reaching the upper valve train components. The cause might be a worn or damaged oil pump, a clogged oil pump pickup screen or a plugged up oil filter. Using too thick a viscosity of motor oil during cold weather can also slow down the flow of oil to the upper valve train, causing noise and wear.
Is there engine light? Engine code?
Engine code help determine which system has problem.
The most likely problem will be Spark Knock (Detonation) caused by an inoperative EGR valve, over advanced ignition timing, engine overheating, carbon buildup in the combustion chambers, or low octane fuel.
SPONSORED LINKS
Thursday, December 17th, 2009 AT 9:04 AM
