1997 Saturn SW2 stalls when reaching almost half hot
1997 SATURN SW2
190,000 MILES • 4 CYL • FWD • AUTOMATIC
LUBI570
When I let cool it will start and run ok, then when driven until reaching running temp, it starts to act like it runs out of fuel. If I try to start it right away it will sputter for about 15-20 seconds and cut off. I had the check engine light codes taken and came up with several codes; PO706...PO122...PO133...PO341.
Autozone pulled the codes for me. And yesterday I checked the throttle position sensor and it was well in the range that it states in the Haynes book for Saturn. What can I check next?
Apr 21, 2010 at 4:57 AM
SATURNTECH9
  • 30,869 POSTS
Anyway u can find a code scanner that can show u freeze frame data on ur code p0122 to show u what ur tps voltage was when the code set?sounds like something is getting hot and failing causing ur stalling.let me know.
Apr 21, 2010 at 10:25 AM
