1997 Saturn SW2 rattleing noise
1997 SATURN SW2
180,000 MILES • 4 CYL • FWD • AUTOMATIC
ATWALL
i changed the idler, tension pullies and the harmonic balancer and still haveing the rattleing sound only when a/c is on and car is in idle give it gas and its goes away.
Aug 1, 2010 at 8:36 AM
SATURNTECH9
  • 30,869 POSTS
You said you replaced the tension pulley you didn't replace the whole belt tensioner assembly the spring loaded pulley?
Aug 1, 2010 at 6:12 PM
ATWALL
[quote:80699dd666="saturntech9"]You said you replaced the tension pulley you didn't replace the whole belt tensioner assembly the spring loaded pulley?[/quote:80699dd666] yes im sorry i did replace the assembly as well as the harmonic balancer and the idler pullley also im thinking its must be the a/c compressor (piston) now its only making the sound when a/c is on but goes away when you take off .
Aug 2, 2010 at 6:39 AM
SATURNTECH9
  • 30,869 POSTS
Have you tried spinning the a/c compressor pulley with the belt off and seeing if it moved side to side?Also have you tried spinning and seeing if the a/c compressor clutch was loose?
Aug 2, 2010 at 6:51 AM
