1997 Saturn SW2 rattleing noise
ATWALL
  • 1997 SATURN SW2
  • 4 CYL
  • FWD
  • 180,000 MILES
I changed the idler, tension pullies and the harmonic balancer and still haveing the rattleing sound only when a/c is on and car is in idle give it gas and its goes away.
Sunday, August 1st, 2010 AT 3:36 PM
SATURNTECH9
  • 30,869 POSTS
You said you replaced the tension pulley you didn't replace the whole belt tensioner assembly the spring loaded pulley?
Monday, August 2nd, 2010 AT 1:12 AM
ATWALL
Yes im sorry I did replace the assembly as well as the harmonic balancer and the idler pullley also im thinking its must be the a/c compressor (piston) now its only making the sound when a/c is on but goes away when you take off.
Monday, August 2nd, 2010 AT 1:39 PM
SATURNTECH9
  • 30,869 POSTS
Have you tried spinning the a/c compressor pulley with the belt off and seeing if it moved side to side?Also have you tried spinning and seeing if the a/c compressor clutch was loose?
Monday, August 2nd, 2010 AT 1:51 PM
