1997 Saturn SW2 Ignition Key Switch
110,000 MILES • 4 CYL • 2WD • MANUAL
EARLE ALLEN
My ignition key switch is bad. Sometimes you have to keep inserting and turning the hey upside down till it finally works. I have a new one but ran into a problem trying to get the old one out. There is a black ring on the outside that won't allow you to remove the plastic cover. With the cover removed I should be able to get at the button to remove the old one. Thank you for your free help.
Earle Allen
Feb 26, 2009 at 12:35 AM
RACEFAN966
  • 5,029 POSTS
Ok remove the upper part of the plastic around the column. Put the key in the switch and turn to acc possition and depress the square locking button on the top of the ignition module assembly and pull the lock cylinder out thats it.
Feb 26, 2009 at 3:05 AM
EARLE ALLEN
Thank you for your reply. The first part you said to remove the upper plastic cover. In order to do that you have to remove the black plastic ring with the key positions marked on it because the ring is larger than the hole in the cover. With that done the rest should be fine .
Waiting for your reply.
Thank you
Earle Allen
Feb 26, 2009 at 4:49 AM
RACEFAN966
  • 5,029 POSTS
With what I can find that sould not be a problem. Could you include a pic so I can see what you are up against? Thanks.
Feb 27, 2009 at 1:54 AM
