1996 Saturn SW2 cylinder compression
1996 SATURN SW2
107,000 MILES • 4 CYL • FWD • AUTOMATIC
MRBIG71252
I have oil on the #1 cylinder spark plug. I performed a compression test and the results were 200, 205, 220 and 225 psi. Isn't this too high? What would this mean?
Oct 12, 2008 at 8:41 AM
DOCFIXIT
  • 18,828 POSTS
that is some serious compression any chance too much oil in engine? If not oil rings bad leaving oil in cylinder acting like za seal bumping up compression. Any smoke from tail pipe?
Oct 12, 2008 at 8:57 AM
MRBIG71252
Oil level is fine. Blue smoke when starting for the first time of the day. Runs rough for about 15 seconds and then seems fine.
Oct 12, 2008 at 10:49 AM
