2000 Saturn SW1
TAMEKAWASH
2000 Saturn SW1 6 cyl
How do I replace the studs for my front passenger side wheel. On a saturn?
Sep 7, 2010 at 6:14 AM
SATURNTECH9
  • 30,869 POSTS
You would remove the wheel,caliper,and rotor.Then take a hammer and tap the old stud out.# Start new wheel stud into hub.
# Place four washers over stud.
# Install wheel mounting nut with flat side toward washer.
# Using a box-end wrench, tighten nut until stud is seated.
Pretty easy to replace them.
Sep 7, 2010 at 6:47 AM
