1998 Saturn SW1 Turn Signals Not working
1998 SATURN SW1
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOBBYG300
  • 5 POSTS
My 98 Saturn Wagon all of a sudden the turn signals stopped working all together. if you move the lever up and down a few times then they will work but only for a short period of time. Neither the driver nor passenger works. What could the problem be and what would be the best resolution for this problem.
Jan 26, 2009 at 2:26 AM
JDL
  • 16,098 POSTS
Hello, you might check the turn fuse in the fuse box. I believe that circuit goes hot when you turn on the key.
I just wondered if the hazzard lites flash? You may have a problem with the turn signal switch?
Jan 26, 2009 at 6:25 AM
BOBBYG300
  • 5 POSTS
Actually nothing works. The Hazzards do not work nor the turning signal. Any help would be greatly appreciated.
Jan 26, 2009 at 6:57 AM
BOBBYG300
  • 5 POSTS
Actually the Hazzards do not work.
[quote:992fa24c15="jdl123"]Hello, you might check the turn fuse in the fuse box. I believe that circuit goes hot when you turn on the key.
I just wondered if the hazzard lites flash? You may have a problem with the turn signal switch?[/quote:992fa24c15]
JDL
  • 16,098 POSTS
It sounds like the turn signal switch. The flasher, it may be a combination flasher, the hazard and turn are wired through the turn switch switch. Maybe a problem with switch or wiring circuit? Because you can wiggle the turn selector and get it to work, makes me think the problem is there.
Jan 26, 2009 at 8:20 AM
BOBBYG300
  • 5 POSTS
What would be the easiest way to fix this problem? I really do not know anything about cars. Any help would be appreciated.
[quote:00cba6a2f4="jdl123"]It sounds like the turn signal switch. The flasher, it may be a combination flasher, the hazard and turn are wired through the turn switch switch. Maybe a problem with switch or wiring circuit? Because you can wiggle the turn selector and get it to work, makes me think the problem is there.[/quote:00cba6a2f4]
Jan 29, 2009 at 3:35 AM
BOBBYG300
  • 5 POSTS
Jan 29, 2009 at 3:36 AM
JDL
  • 16,098 POSTS
Hello, I'd check the fuses, first, then the flasher.
Jan 30, 2009 at 12:06 AM
